this is what we found... most of you would have seen this before...
greg rewired the car through out...
took a little while to get into it.. but just about there...
started with engine... turned over the 'rebuilt engine'... a little fuel in the carby and fired straight away...
fuel tank was rusted out around fuel sender.. so thanks to rob (forum member) scored a replacement...
once new tank in.. turned engine again.. and it sounded like someone running their finger nails over a black board... but ran ...
pulled off the sump... anyone seen metallic oil before... ? looked great but... clearances not quite right...
rebuilt motor needs rebuilding
so out with the new.. and new gasket set through the spare motor.. rear main.. welch plugs... fiber timing gear...
turned it over.. good.. and quiet... fiber gear heaps quieter that the steel set i put in the wagon !!
front of both sills had rust.. not too bad... quick tidy up...
looks as though the ute has been hit from behind at some point.. a bit of a mess in lh rear quarter.
was going to replace the checker plate at the spare wheel door... but one you start digging.... might be a job for another day... but a hit of matt black and a new ply tray sorted that.. out of sight.. out of mind.. for the moment
new windscreen and door glass...
new door trim and front seat reupholstered... and new tarp
repro floor matt...
new brake drums, shoes and cylinders...
a few door rubbers to do... a couple of tail light lenses.. and hopefully.. roadworthy... next week !
this is where it sits at the moment...
it aint going to win any awards... a few dings here and there.. but overall pretty straight... and i think she looks pretty cool...
p.s... anyone got a wiper motor that they want to part with... will be rewarded with some cold hard cash !
stu
