HR wishbone spaces
HR wishbone spaces
I have recently discovered that the bushes I had replaced by a renowned local mechanic 12 months ago were not installed correctly and I need to pull them out and redo them to get the bushes sitting properly and the spaces even.
Does anyone know what the dimension is for both top and bottom HR wishbones, so I can wip up a set of tools?
I can do it with a vernier, but I'm thinking the tool would make it a better job when tightening the bushes.
I have everything crossed that the holes are still OK, or that will be another degree of difficulty altogether🙄.
Many thanks,
Brett
Re: HR wishbone spaces
Brett,
If there's equal spacing between the lower arms and the crossmember front and rear, then the arms are in the right position. If the bushes haven't been screwed all the way into the arms (hex hard up against the arms), then "just" screw them in until they're home. If you have to start all over again, then -
For the lower control arms, equal spacing between control arm and crossmember at the front and rear is what you want. It equates to equal protrusion of the shaft through the control arm at front and rear (about 1 mm from memory).
The spacers are only needed if installing a new control arm. Yours have already been in service, so the bushes have already cut the obtuse threads in the control arm.
The trick here is to line up the arm on the shaft, as above. Dip the bush in gear oil and start it on the shaft at the front. Hold the arm against the bump stop to begin with. The bush should "pick up" the thread in the control arm almost immediately. If you notice that the control arm is being pushed back as you turn the bush, unscrew the bush, let the arm hang vertically, and try again until the bush starts in the control arm. Now do the same for the bush at the rear. If you can't make the threads index in the control arm, lever the end of the arm outwards a little until the threads pick up.
The manual says tighten the bushes to 35 lb-ft.
If you're installing replacement bushes to control arms that have only had the genuine article, be prepared for the fight of your life. The Rares bushes are oversize on the outer threads.
The upper control arm bushes are installed similarly, but access can be a bit tight on the vehicle. The alternative is to use a vice with suitable spacers.
Best of luck.
Many thanks for your reply Rob.
I understand the equal distance measure method and used that on the sedan front end. On the ute though, I am a little worried that the arms might have been spread out and I was thinking that if I had the tool it would sort that issue out. If nothing comes up, I will used the verniers and cross my fingers.
While I have you, I was also thinking that there will be no need to do a wheel alignment after this job because I am not changing any of the angles. What do you think?
Brett,
If the fore-and-aft position of any of the control arms changes, then your caster will change as a result and you'll have to tweak it back. Camber and toe-in should be relatively unchanged.
Do the work and take the car for a drive. If the car pulls to one side (thinks . . . HR front suspension) take away one thick shim from the forward shim stack on the side to which the car pulls.
Thanks Rob. Much appreciated.
Brett
I've got these ones:
a) Austaloy 3A4-1 (also Litchfield E1883) control arm remover/installer EH-HR.
b) Litchfield E1894 (=3A11) lower control arm spacer HD-HK.
c) Austaloy 3A12 (=Litchfield E1895) upper control arm spacer HD-HR.
Happy to loan them to you (or measure them for you) if it helps, though I don't get home from work until next weekend.
Thanks for the offer Harv. I will borrow them if I may, when you get back.
Given there are so many HR fronts are out there, I'll take a few pics and post the process when it happens.
ardiesse wrote: Sat Aug 01, 2026 4:30 pm Brett,
Best of luck.
that's good to read i've never used a tool never even knew one existed till i had seen them advertised :lol: but done pretty much what you described never had an issue
Brett027 wrote: Sat Aug 01, 2026 9:13 pm Thanks for the offer Harv. I will borrow them if I may, when you get back.
No problem. PM me a name and address, and I'll post them next Friday or Saturday. Post them back when you are done.
At the last nationals in Stanthorpe on of the NSW cars had the bush fall out of the lower control arm, HR front end.
They did find it down the road and put it back in, pays to check the torque and not let them go without grease !
If you end up with mor caster that can’t be bad on the HR front. If less then as rob says, but I would swap the shim front to back rather than just remove it SL together as this will maintain your camber setting.
