Chev EK
Re: Chev EK
PM sent Joe.
Re: Chev EK
So i have been having a small issue with the wheel alignment on the Torana front end and although its not that bad its been a thorn in my side since i have finished and been driving around.
What the issue is, the offset bushes i have in the lower control arms to do wheel alignments get knocked out and needs continual adjustments to keep the tyres from wearing out.
Today I took delivery of some custom upper control arms that are adjustable via rose joint adapters. This will let me align the caster / camber and lock it in on a more permanent basis.
It will also allow me to use rubber bushes on the bottom arms that will help dampen road noise.
All i have to do is drop the front end out and do the replacement, argggghhh, not an easy task.
Re: Chev EK
Pretty cool. Wonder if they do them for HR. Do you really need to stop the whole crossmember out Greg? Not that I know anything about traanas.
Bushcreature
Re: Chev EK
Post by Bushcreature »
G'day Greg, where did you source these upper arms from?
Thanks.
BC.
Re: Chev EK
Bushcreature wrote: Thu Feb 19, 2026 6:20 pm G'day Greg, where did you source these upper arms from?
Thanks.
BC.
Hi BC,
Here
https://www.facebook.com/marketplace/it ... 548b985868
Not 100% happy with the quality, i am fussy though, just little bits like welds and slight alignment diiferences between the 2 arms, they will adjust out but i have OCD !!!!
