LS1EK
- WesternWagon
- State: WA
Re: LS1EK
look Killa
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
Re: LS1EK
Some more progress, one side of the engine bay all smoothed out. Will be going for a satin black finish.
- IMG_3710.jpeg (3.59 MiB) Viewed 735 times
- IMG_3711.jpeg (3.78 MiB) Viewed 735 times
- IMG_3740.jpeg (3.45 MiB) Viewed 735 times
Re: LS1EK
Been scratching my head on how I was going to fix the fire wall where I stuffed it from welding on the inside.
In the end the solution was easy, I just made a new section and put it straight over the top. Plugged weld a few spots around the edges and glue the middle sections with silaflex.
- IMG_3748.jpeg (1.92 MiB) Viewed 692 times
- IMG_3749.jpeg (2.73 MiB) Viewed 692 times
- IMG_3751.jpeg (3.35 MiB) Viewed 692 times
Re: LS1EK
Thats the trick,
You can tell your engineer that is double plated to increase the strength, should get some points there.
I'm assuming that black is epoxy primer you will rub back once the painting starts ?
Keep going mate your on the home stretch.
