First thing is to discuss this with your engineer!
This is torana front as it came out of the Torana:
Knotch out the frame, make sure it is cut level and square:
Add the supports at the end:
Add a strip brace here:
Tack on the EK mounts and trial fit BEFORE drilling holes and welding:
Make the supports for the rear Outrigger mounts:
Mounts for the outrigger:
Weld on the chassis doubler plate:
I knotched out this area to make it possible to adjust the frontend alignment without going "STIR CRAZY"!!
Make the engine mounts (I used 75 x 50 x 4 RHS)
This section of the mount is notched to clear the Rack and Pinion input shaft:
Full prefit prior to paint:
Fit all the new bushes:
Finally bolt it in:
Hope this helps someone.
