Page 1 of 3
Dr Blacky attempts to perform an addagruntome
Posted: Tue Dec 05, 2023 11:16 pm
With the utes prodigious drinking problem starting to become a concern - 11 litres of oil in a 1000km trip to Albany and back
, the Holden Hospital decided it was time to start looking for a donor heart for the poor old girl.
Admission time …..
Re: Dr Blacky attempts to perform an addagruntome
Posted: Tue Dec 05, 2023 11:26 pm
This particular donor heart came from me old mate Micks car - he was told it was terminal due to too much end float in the crank even though it ran OK - he ended up getting another donk reconditioned and mothballed this one
Onto the operating table you go old girl -
We started to inspect all her orifices , found a couple of areas of concern , a mild case of corrodius bungholius in the rear pots but nothing too concerning …..
Posted: Tue Dec 05, 2023 11:29 pm
Went through from front to back and found this -
Front pot before
And after
Posted: Tue Dec 05, 2023 11:33 pm
Posted: Tue Dec 05, 2023 11:35 pm
Except for #6 which is an odd colour
Bores appear to be original ?
Don’t have a proper bore gauge/micrometer so this is the best I can manage - we ARE just a backyard surgery after all
Posted: Tue Dec 05, 2023 11:39 pm
Then we measured the end float in the crank - hhhhmmmm ……..
Does seem excessive, however it was time for the doctors to repair to the think tank for a tall glass of adult cordial and some post operative discussion- the autopsy will conclude tomorrow
Posted: Wed Dec 06, 2023 6:37 am
Only a ciggie paper or two.....
Posted: Wed Dec 06, 2023 8:21 am
Scalpel.
Scalpel.
Retractors.
Retractors.
Bushchook.
Bushchook???
That end float appears terminal Doctor. A donor crank from some unfortunate soul may help. We could always get the lanterns, shovels and hessian bags out and visit the cemetery after dark...
Posted: Wed Dec 06, 2023 8:27 am
Posted: Wed Dec 06, 2023 9:32 am
by ardiesse
Blacky,
Not quite original bores - it's been been bored out to 3-1/16" + 0.040".
OK, so 0.007" end float on the crank. My Humpy wasn't much better than that. Maybe it'll come up better with new main bearings (?)
Posted: Wed Dec 06, 2023 9:45 am
ardiesse wrote: ↑Wed Dec 06, 2023 9:32 am
Blacky,
The markings on top of the pistons are quite cryptic Rob, just random letters - not sure what to make of them TBH
i am hoping it a worn bearing not a buggered crank
Posted: Wed Dec 06, 2023 12:44 pm
For some piston manufacturers, each letter represents a piston that is 0.1 thou bigger than the intended bore size. They are measured after machining, just before fitting. You then select a piston that matches the final machined bore size.
If the bore size is supposed to be 3 1/16 + 40 thou (3.1025"), then:
a piston stamped A is 3.1025" diameter
a piston stamped B is 3.1026" diameter
a piston stamped C is 3.1027" diameter
a piston stamped D is 3.1028" diameter
a piston stamped E is 3.1029" diameter
a piston stamped F is 3.1030" diameter
a piston stamped G is 3.1031" diameter
a piston stamped H is 3.1032" diameter
a piston stamped I is 3.1033" diameter
a piston stamped J is 3.1034" diameter
a piston stamped K is 3.1035" diameter
a piston stamped L is 3.1036" diameter
a piston stamped M is 3.1037" diameter
a piston stamped N is 3.1038" diameter
a piston stamped O is 3.1039" diameter
a piston stamped P is 3.1040" diameter
a piston stamped Q is 3.1041" diameter
a piston stamped R is 3.1042" diameter
a piston stamped S is 3.1043" diameter
a piston stamped T is 3.1044" diameter
a piston stamped U is 3.1045" diameter
a piston stamped V is 3.1046" diameter
a piston stamped W is 3.1047" diameter
a piston stamped X is 3.1048" diameter
a piston stamped Y is 3.1049" diameter
a piston stamped Z is 3.1050" diameter
Two letters stamped? No idea.
Posted: Wed Dec 06, 2023 2:00 pm
Two letters for oval pistons?!
Posted: Wed Dec 06, 2023 2:25 pm
Posted: Wed Dec 06, 2023 11:44 pm
Yanked the main caps and big ends for a looksee today
Rear main looks new , all of them are .010
The front one had a funny looking mark in the bearing but the crank looks fine
Crank seems OK - one side
Other side
