No go Help
Posted: Sun Jun 25, 2023 10:35 am
by Utey
Hi
Just replaced extractors think I reconnected everything engine fires runs with throttle bit lumpy
then stops no idle starts every time but no run
Running perfectly before replacement.
Sure its something obvious just can't find it
Any help ideas greatly appreciated
Nick
Re: No go Help
Posted: Sun Jun 25, 2023 11:10 am
Could have dislodged crap into the needle and seat. Blow them out, refit, run with top off carb and see if fuel level is maintained in float bowl.
Could be a honking great air leak at the manifold. With motor cold (to avoid a fire) spray WD40 around the manifold whilst running. If the engine picks up, it is sucking through a leak.
Re: No go Help
Posted: Mon Jun 26, 2023 1:18 pm
by Utey
Thanks Harv for the fast response
Leaking at the manifold I used the existing gasket!would that cause the problem?
I guess undo and refit?
This is a straight forward exercise , just position and tighten?
Thanks
Nick
Re: No go Help
Posted: Mon Jun 26, 2023 2:05 pm
by EK283
Yes gasket sealing is extremely important, it changes everything the car needs to run because of the vacuum.
Vacuum effects everything, fuel mixture to timing, if thats not right them no go ! Parden the pun.
Put a new gasket in, the reason is they squash with the first tension and dont spring back, if you move the manifold in any way after that it will more than likely not seal and cause issues.
