Got the block and crank washed down and blown out, ready for dummy assembly. Figure it can have another clean before final assembly, but for now I can bolt stuff together without worrying about getting swarf where it shouldn’t be. It’s likely I will have to flog out the pushrod “guide holes” due to the Repco pushrod angles, so final full clean and paint is not on the cards quite yet.
Chased out the block holes with a tap before washing, though didn’t chase the mains and head holes. These will have studs, so no need for the threads to be perfect for torque settings – figure they are better off slightly tight than loose, the same way Henry made flathead block holes.
Dummied up the crank, main caps and girdle. Main studs are 7/16-20UNF/14UNCx4”, with 1” of thread either end (ARP part number ARAP4.000-1LB). They are a bit longer than normal to clear the girdle and spacers – for standard main caps, they can be shorter at 3.125” long (AP3.125-1LB). Haven’t torqued them down yet, but at finger tight the girdle fouls on the second rearmost crank counterweight. It doesn’t hit by much, and might fix itself once torqued down (doubt it though). In any case, I need to butcher that part of the girdle out for the dry sump, so no tears yet. Will save the girdle butchery until the dry sump is here. When I get a chance I’ll clean up a standard sump and take some photos to show where the girdle clashes.
Found the crank and cam gears. One of the few joys of getting old and forgetful is that when you find stuff you have stashed away it is like Christmas all over again. The gearset is a Master Engineering GS138 adjustable timing set. I bought two of these sets as part of the Master Engineering closing down sale years ago. I need to do some learning though as I don't fully understand the keyway angles. Assuming that the "0" point is zero degrees, the advanced "A" keyway is 125º around the crank, whilst the retarded "R" keyway is 105º.
- Master Engineering GS138 adjustable timing gear sheet.jpg (854.78 KiB) Viewed 951 times
- Master Engineering GS138 adjustable timing gear set.jpg (1001.02 KiB) Viewed 951 times
Gut feel is that's a lot of crank degrees, but my mind is thinking of ignition timing, not piston/valve timing so perhaps not so drastic.
Photos from places like Rollmaster show the following (this is a chain drive, but the gear drives for the red motor are similar):
- Rollmaster adjustable crank gear.jpg (14.73 KiB) Viewed 951 times
This looks better... 2º, 4º, 6º, 8º of change (not 100-oddº). But how do those little degrees of timing marked on the gear change relate to the big actual angles of the keyways on the crank gear? More learning for me to do yet. Might give Clive a call and get his opinion, though for now I’ve got the crank gear set straight up.
Pressed the cam gear on (even remembered to put the retainer on first
), and got a good 5-thou end float. The iron cam gear was a lot nicer to slide on than the last steel one I did. It’s about now that I remembered that the engine front plate I need is currently propping up the dummy block in the FED. Might be a while before I get that plate home, but for now not a drama… plenty of other stuff to check. Checked the cam bearings to make sure the oil holes were aligned, must remind myself later on (when I can’t get oil to the top end
). The cam slides into place nicely. Swapped out the two GMH retainer bolts (¼-20UNCx¾”) with some ARP ones (part number 640-0750).
Replaced the oil gallery and water jacket plugs with some allan-head ones (¼-18 NPT and 1/8-27NPT). The dry sump will not need a dipstick, so that hole needs a plug too. Dipstick hole is 11/32”, which is close enough to 21/64 (the drill size for tapping 1/8 NPT)… this plug will only be under crankcase pressure, so slightly sloppy will be OK. When I get a chance I’ll run the tap down the hole and fit a plug.
