Strange diff center markings
Posted: Sun Jun 04, 2017 5:41 pm
by Rapps
Hello All.
I have just pulled the diff center from the EK ute to fit a 3.55. The center I removed had no stamp on the front collar and I just found these numbers after HOLDEN 740395 MN can anyone identify this center?
Re: Strange diff center markings
Posted: Sun Jun 04, 2017 7:22 pm
If the centre is out just read the ratio off the crown wheel ???
Posted: Sun Jun 04, 2017 7:48 pm
by Craig Allardyce
What where the numbers actually stamped in? The case or crown wheel gear? I think your a digit short too.
Posted: Mon Jun 05, 2017 7:13 am
by Rapps
it is stamped on the crown wheel 7407395 MN
- ek diff.jpg (84.13 KiB) Viewed 2084 times
Posted: Mon Jun 05, 2017 12:18 pm
If I read that part number as 7407395, then the Master OldFarts Dogologue indicates that it is a differential pinion flange slinger for FJ from engine number 136885.
Posted: Mon Jun 05, 2017 1:06 pm
by Craig Allardyce
Yeh I read that too Andrew.
The part number pictured does match what I have here for a 3.89 crown wheel. The number is pretty much useless as a reference in the master cat as it only lists matched set crown wheel and pinions by different numbers. The part number stamped on the crown wheel would have been for identification prior to lapping and setting with its mating pinion gear. After that both gears would have been stocked as a set under another number. No other numbers are on the crown wheel apart from engraved serial number and pinion positioning dimension.
Posted: Mon Jun 05, 2017 4:33 pm
by Rapps
thanks Gents that explains the old girl howling its head off at 60mph with 185/75/13's
It will now have a 3.55 and 185/65/14 's
Posted: Mon Jun 05, 2017 6:49 pm
My calculations say you would be reducing your revs at a mile a minute from 3279 to 3051. Equivalent to 7.5% overdrive.
If you were to stick with your current wheel tyre combo and just change the centre you would achieve a 10% overdrive. Something to think about.
Posted: Tue Jun 06, 2017 6:07 am
by Rapps
OK thanks Errol. We are going to Gosford next week and will try both sets.
Going to that museum with our car club on Saturday
Posted: Mon Jun 19, 2017 6:44 pm
by Rapps
Here is the update on the Ute. This past weekend we traveled just over 500 miles round trip and it ran just great (saw a black sedan heading north at Port Maquarrie and just thundering )
She has stopped howling at the 60 mph now. I agree that the 13's may be better so will try that again.
This is it's second large trip since I got it out of a shed No problems
Posted: Mon Jun 19, 2017 10:54 pm
by In the Shed
Good stuff, do you know what the engine rpm is at 60 mph?
Posted: Tue Jun 20, 2017 7:01 am
by Rapps
Thanks Stephen , I don't have a tach in it but it is easy on the ears now and cost around $80.00 in fuel for the 500 miles at around $1.45 per litre.
I am very happy with it
Regards Lindsay
Posted: Wed Jun 21, 2017 9:39 am
by FireKraka
Hi Rapps;
Now that it is running really well you can plan to come to Perth for the Nationals next year
Neil H
Posted: Wed Jun 21, 2017 5:18 pm
by Rapps
Yes that could be an idea.
