Grey motor harmonic balancer - gentle installation.
Posted: Thu Feb 11, 2016 10:42 am
A few months back I was chasing vibration in the FB. The harmonic balancer (a red-motor type aftermarket job) showed quite a bit of wobble, so I chose to replace it. I struggled to get a replacement from Rares due to a supplier issue with Dayco (this may have since been resolved). I ended up buying a Tuffbond balancer from Ross. The balancer (part number 116543) is one of their Metal Jacket jobs, and beautifully made. The main drama I had is that the balancer clashes with the standard grey motor fan, and I ended up notching the fan blades to suit.
One thing I noticed during the installation is that the interference fit between the crank and the Ross balancer is a lot tighter than the normal replacement balancer. I followed normal practice for oiling, and checking for burrs and rough spots on both the crank and balancer – all good. The instructions for the Ross balancer are quite specific that they should be installed with an “installation tool”, not smacked on with a BFH and lump of wood. The BFH method is pretty standard grey motor practice (either with a lump of wood or the fancy service tool that screws into an original balancer).
I know a lot of other vehicle cranks are fitted with drilled crank snout centres. This allows a bolt to be installed, and the “installation tool” to gently squeeze the harmonic balancer onto the crank. This removes the BFH, and has got to be a good thing for the thrust bearings. I’m guessing that it would be possible to drill and tap the standard grey motor crank snout to accept a bolt. I could then make an “installation tool” that uses the bolt to drive on the Ross balancer.
Has anyone drilled and tapped the grey motor crank snout for this? Are there any other (gentle) ways of installing the harmonic balancer on a grey that doesn't load up the thrust bearings?
