Quick question for those of you who have been there n' done that.. I'm running stock 13", at stock height, so how low can i drop her before i get scrapin and scrubin?
I've heard different things, so wondering what others here have done and experienced with this.
How low can i go?
How low can i go?
Los Locos C.C.
http://www.facebook.com/loslocos.carclub
Re: How low can i go?
All the way down to the bumpstops... If you like a harsh ride
The biggest factor to how low though is what hangs underneath? If everything is tucked up close to the body and doesn't hang below the sills you can drop it till the sills are at the 100mm limit.
Mine has'nt scraped on anything yet and it sits at a good height. No idea how much its dropped though as i was given the HR forntend springs and all.
With an original front end and stock wheels, it will go lower than practical at the front.
I've cut bump stops in half, which gave me about 1/2" clearance on the stops.
Ended up bending a lower wishbone.
On the rear, the tailshaft that will rub on the floor / rear of trans tunnel hump.
This will require stops drastically reduced or tossed aside altogether.
HR front ends have high chassis mounting pads which limit coolness.
Jeff
Jeff
Mine is as low as you can go - drives like an old landcruiser - crap. Keeps you on your toes when driving
13" wheels and 185/65 tyres (i think? from memory) Kingpin front end on bumpstops, diff on 2" blocks and the springs look like they're either sagged or reset
Only things that scrape is the muffler going over the tops of steep ramps in car parks, and the end of the exhaust pipe as mine sticks out from the bumper a bit.
If you did a bit of creative thinking and put some sort of heat shield under the floor you could bring the exhaust closer to the floor and you would probably clear just about anything.
I can still even drive my car up gutters when I have to without scraping.
my old ek ute had dropped spindles with two inch lower springs with a coil cut off and rear springs lowered 2inchs with 2 inch blocks running 185 x 75 13inch tires .drove pretty good no scrapes wasnt to harsh a ride ask mini he drove it and was supprised how comfortable it was
regards fatboy
regards fatboy
