Hey all
Looking for some advice on what 14” rims fit an EK drum brake front end
I have some HT pattern 14 x 6 and they have a 4 ½” back space. The original 13’s have on a 3 ½ .
The 14’s hit the tie rod end, is there a 14 with a 3 ½ back space or do I need to get them made?
Gazza
EK 14 front rims?
- WesternWagon
- State: WA
EK 14 front rims?
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
Re: EK 14 ront rims?
I have them on a HR disc front and I had to get the off-set changed cause I had the same problem.
HT HG have less back space than the HK do but they will still hit.
- WesternWagon
- State: WA
Cheers Trev
I used some spacers for the short term 5mm did the trick and longer wheel studs. Will get some rims made up.
3 1/2 " Back space should do the trck I think?
Gazza
Gazza
:ASRF Member
:ASRF Member
I ran HT 14 x 5.5s on my last EK (stock front end) with no hassles- the tie rods were close but didnt foul. I think these rims have the same backspace (4.5 inch)
Like Trev I had to get the same rims offset changed to fit on the HR disc front. I put 14 x 6s on the back as they have a similar dish to the reset 5.5s.
What size tyres did you run on the front of the drum brake front end mate?jake08 wrote:I ran HT 14 x 5.5s on my last EK (stock front end) with no hassles- the tie rods were close but didnt foul. I think these rims have the same backspace (4.5 inch)
Stock as a rock
Not so stock
Stock as a rock
Not so stock
Re: EK 14 front rims?
I used the same tyres on both- 195/75R14s
I am pretty sue the offsets r different on hk verses ht hg
I have a set (3 = 2 front + a spare) with 195/75/14 white wall tyres and an extra Whitewall (4th) if anyone is interested?
Make me an offer .
Make me an offer .
