Moderators: reidy , Blacky
Posts: 5093 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Fri Sep 25, 2020 1:49 pm
Ahhh... thats better. 7psi or so... spot-on for a vane blower.
Tacho is a little more difficult with a maggie, but not impossible. No mechanical tach drive in your maggie, so you will need a signal convertor to pick up the tacho feed, then you can use whatever tacho you fancy.
Something like these, but be careful as some are only suitable for external coil maggies (yours is internal coil):
https://www.huntmagnetos.com/products/j ... erter.html
https://www.speedwaymotors.com/AutoMete ... r,103.html
Amen.
Posts: 1833 Joined: Wed Nov 11, 2015 4:54 pm
Post
by FJWALLY » Fri Sep 25, 2020 2:06 pm
Yeah I think there is more puff in there I havent dare summon yet
Tks for the tip - a quick look rules out the speedway unit but I’ll see what Rodger Howard comes up with now I have that info
Posts: 1131 Joined: Mon Apr 26, 2010 2:08 pm
Post
by gpi » Fri Sep 25, 2020 2:34 pm
great work
have you decided where you are putting the switch for the mag yet?
Post
by FJWALLY » Fri Sep 25, 2020 2:38 pm
gpi wrote: great work
Not yet - going to work it through with sparky - hopefully through the ignition but maybe with an extra kill switch nearby as a backup
Posts: 2310 Joined: Thu Apr 18, 2019 4:14 am
Post
by Brett027 » Fri Sep 25, 2020 3:35 pm
That motor sounds so sweet. Congratulations on a fine engineering achievement.
Post
by gpi » Fri Sep 25, 2020 4:43 pm
FJWALLY wrote: ↑ Fri Sep 25, 2020 2:38 pm
as Harv advised, this is the sig generator for your mag
Post
by gpi » Fri Sep 25, 2020 5:09 pm
Post
by FJWALLY » Fri Sep 25, 2020 5:12 pm
Thanks - they both look like good solutions
Post
by FJWALLY » Fri Sep 25, 2020 5:13 pm
Brett027 wrote: That motor sounds so sweet. Congratulations on a fine engineering achievement.
Cheers Brett - to say I was a happy camper this morning was a big understatement
Posts: 9818 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Fri Sep 25, 2020 5:35 pm
That sounds great Rob
Tyre frying time heh heh
Post
by FJWALLY » Fri Sep 25, 2020 5:43 pm
Cheers Clay - Yes a little smoke might release from the donuts once it's back on the road.
Errol62 wrote: ↑ Fri Sep 25, 2020 5:35 pm
Post
by FJWALLY » Sat Oct 03, 2020 11:34 am
Linkage on and working - needs some finessing on springs etc but seams to be functional - clutch slave should be back midweek then bleed systems and maybe a little drive
Post
by Errol62 » Sat Oct 03, 2020 2:34 pm
I notice you aren’t running the firewall mounted throttle return spring rob.
Post
by FJWALLY » Sat Oct 03, 2020 5:01 pm
Errol62 wrote: I notice you aren’t running the firewall mounted throttle return spring rob.
Had it in the back of my mind but forgot how it goes - will check the book as I dont like the one on the vac hose - very agricultural
Post
by FJWALLY » Tue Oct 06, 2020 8:55 am
Ok so that pull back spring is a much better solution than my dodgy spring but where can I get one? Is there a new one available somewhere?
