Fitting HR Disk Brake Front End To Ek
Squirralien
Re: Fitting HR Disk Brake Front End To Ek
Post by Squirralien »
Thanks ill have to look in to that, not sure what its like in S.A.
Thanks
Steven
Check out my daughters Website and read her story, Take away from it what you do and pass it on to friends and family to read, Awareness is the purpose, Know your rights in hospital and Know and learn the condition
www.melissas.net
ekstevo
Post by ekstevo »
Devilrod wrote:You need the HR to EK front end rubber mount kit from Rares (someone will know the exact name and part no, can't remember) and also you need to change the outrigger (the bit sticking out the front) ie: take of the HR one and fit the EK one. thats just a start, if you do a search you will find alot of existing info on this swap.
pretty shaw rares part number for the kit you want is FEK4A it has an ek outrigger rubber and the 4 hr member to subframe rubbers.
the rubbers that go with the kingping member dont fit the ball joint member
