Steering wheel repair
LYNCHPIN
Post by LYNCHPIN »
What is the best method of filling the gaps in the cracks in a steering wheel so the filler doesn't fall out with movement.
I was going to replace the old wheel due to cracks, but might keep it if i can repair it or have it repaired.
Lynchpin
FB MAD
Post by FB MAD »
I've got a feeling this may have been covered before in a post a while back.Will see if I can find it for ya.
FB MAD
Post by FB MAD »
Have a look under "Interior" section on 9/9/08 ..... "Steering Wheel Restoration".
There's some good info there from others who have done it.
EKSPCL
Post by EKSPCL »
My 6yr old daughter said
LYNCHPIN
Post by LYNCHPIN »
G'Day Trev,
I read your reply on the post attached and was wondering how wide you have to cut the cracks out to drill the holes to get an anchor point for the Knead it.
Also, can you weaken the steering wheel by cutting the cracks too wide?
Cheers Paul
Gaps, wide enough to get a drill bit in there.
The wheel has a frame that holds it together, so I wouldn't worry about that, Trev 8) .
oldnek
Post by oldnek »
Here tis .......good video
http://www.kbs-coatings.com.au/KBS-Inst ... _76-1.html
Regards John
EKjimmy
Post by EKjimmy »
where do you get kneed it from? repco and autobarn don't seem to stock it...just trying metal reinforced filler at the moment as i thought it'd give a tougher bond-but geez is it a prick to work with in small gaps!
Looks like i might have to clean it all out and start again :evil:
EKjimmy
Post by EKjimmy »
Nevermind! got some from good old bunnings warehouse. It's a pretty interesting product...according to Selleys you can use it to:
Repair small engine parts :shock:
Fill cracks in battery cases :roll:
and
Fabricate nuts and bolts :lol:
Sounds like a minitrucker's toolkit :P
But seriously, hopefully this stuff will give me a good result- nu metal or whatever i was using is s*%$
oldnek
Re:
Post by oldnek »
EKjimmy wrote:Nevermind! got some from good old bunnings warehouse. It's a pretty interesting product...according to Selleys you can use it to:
Don't use it on small or any engines It cracks and gives way after a while.
ash
Re: Steering wheel repair
Post by ash »
Personally I would use Devcon instead of "Kneed-It"
Its much, much tougher and is easier to force into small gaps.
jack_fc
Post by jack_fc »
ash wrote:Personally I would use Devcon instead of "Kneed-It"
I agree 100% with ash; only prob is it's much more expensive, and last time I bought some, was only available in a relatively large quantity...
artyfartymarty
Post by artyfartymarty »
i repaired my steering wheel and gave it a fresh new coat of paint a while back now...with the full cycle of the seasons the cracks are back.
they appear at the join between the original s/wheel material and the new filler....looks like the bond has failed or the plastics expand/contract at different rates.
anyone else got the same results? anyone got a solution for this i can try when its time to repaint again...other than pearlcraft?
FB EK Club WA
Don't follow me, I'm lost too
