Capacities (Imperial)
Fuel tank - 9 1/2 gallons
Crankcase (refill) - 3 quarts
Cooling system -
- Synchromesh trans 8 quarts
- Hydra-matic 6.9 quarts
Transmission -
- Synchromesh 1 2/3 pints
- Hydra-matic 13 pints (dry)
Rear axle 1 3/4 pints
Wheels and Tyres
Wheel size 13 x 4.50 J
Tyre - type Tubeless
- size 6.40" x 13"
No. of Plies -
- 215, 225, 219, 229 4
- 2104, 2106 6
Tyre pressures - ( lbs/sq in - cold)
Models front rear
215, 225 22 22
219, 229 (unladen) 22 22
(full laden) 22 26
2104, 2106 (unladen)22 22
(full laden) 24 28
* Station sedans operating continuously under full load conditions should be fitted with six ply tyres.
Adjustments
Intake Valve Clearance .008 in. Hot
Exhaust Valve Clearance .012 in. Hot
Distributor Point opening .012 - .016 in.
Spark Plug Gap .028 in - .033 in.
Clutch and brake pedal free travel (or lash) 1/8 in.
Clutch Rork Operating Rod Free Travel (or lash) .080 in or 5/64"
EK General Specifications
Re: EK General Specifications
rosco wrote:Capacities (Imperial)
Fuel tank - 9 1/2 gallons 43.1 Lts
Crankcase (refill) - 3 quarts 2.8 lts
Cooling system -
- Synchromesh trans 8 quarts 7.5 Lts
- Hydra-matic 6.9 quarts 6.5 Lts
Transmission -
- Synchromesh 1 2/3 pints 1 lts
- Hydra-matic 13 pints (dry) 7.4 Lts
Rear axle 1 3/4 pints 1.2 Lts
Wheels and Tyres
- size 6.40" x 13"
No. of Plies -
- 2104, 2106 6
Models front rear
215, 225 22 22
(full laden) 22 26
(full laden) 24 28
Adjustments
Intake Valve Clearance .008 in. Hot 0.23mm
Exhaust Valve Clearance .012 in. Hot 0.305mm
Distributor Point opening .012 - .016 in. 0.40mm
Spark Plug Gap .028 in - .033 in. 0.711 - 0.84mm
Clutch and brake pedal free travel (or lash) 1/8 in. 0.003mm
Clutch Rork Operating Rod Free Travel (or lash) .080 in or 5/64"2.32mm
for those who are metrically minded.
Cheers mate !! Always guessed that the normal tank was 45liters in the sedan , good to knowfor those who are metrically minded.
distrgard ..need to read posts ahahha
I should read posts better
