Replacing Column Gear Lever
Hi All
Have a replacement gear lever to fit on the column. I see I need to tap out the roll pin and there will be an anti rattle spring on the end of the lever. Question, is the small plastic bush (where the end of the gear lever fits into) likely to fall out and drop down the column somewhere?
Thanks in advance.
Re: Replacing Column Gear Lever
Hi Stephen,
I would say it is not likely, however possible. More likely it is either missing already or worn out. If it did drop down the column it isn’t a huge big deal and you can replace it using one of the plastic cups from the door trim clips. Just cut the brim off as it were. I have a few if you need one.
Thanks Clay
Sounds like it should be straight forward 👍
