Getting into neutral without column gear shift
So I'm getting my steering box rebuilt in the FB. Have removed the column etc but forgot to put into neutral...rookie mistake :oops:
I'm assuming I can still push the clutch in and manipulate the linkages off the gearbox...
Any helpful tips on which way to push / pull the top and bottom linkages to find neutral...?
Stewart
Re: Getting into neutral without column gear shift
probably stating the obvious but you will need both planes of the shift arm in their central position .....
This may help.
Linkage positions.png (16.37 KiB) Viewed 837 times
thanks guys that a big help :thumbsup:
