I'm fitting 307 to EK.The 307 currently has no engine mounts.
When fitting small block chev to FB/EK using Castlemaine Rod Shop modified HR front end with front mount Torana rack.............................................................
............... Which is the best engine mount to use??....... and why??
I'm thinking HK/T/G
Don't have access to any of the different mounts to appraise and don't have the $$$ to buy every different type ever made to see which fits best so was hoping someone here already running a SBC in an FB/EK can advise as to which is best to get for the install to save my time and $$$.
One other thing, I intend to run T350 trans on the 307 with a column shift if that makes the choice of engine mount more clear.
Thanks for any help in advance
