by rosco » Sat Jan 26, 2008 7:16 am
Hi Dave,
I am enjoying the posts of your work - and am sure others must be equally chuffed.
I am amazed at the quality of your metal work (not to mention the result with Killrust enamel.............)
I sprayed my diff housing, fuel tank and spare wheel housing (and a few other local areas not intentionally) with the same paint - it does work great, but like other enamels - just have to stop yourself going for that "little" bit more body gloss........... been the victim of a few block backs.
I have just finished removing the factory deadener mat from the boot - I have always looked after this area and was quite shocked to find what lay underneath - especially at the base of the rise - it must be a collection point.
Fortunately it was only superficial - spent a month getting it back to shiny steel, RS-1, fishoilene, primer and three (so far) coats of hammered metal epoxy.
I drilled three (3) 4 mm holes into the "low" spots should anything else find its way in. It is the experience of many of us, that if you have a good coat of wax over your boot and open it quickly when it rains - the water gushes down, onto the back window then ebbs back into the boot - I think this is probably from where much of the rust damage emanates.
Just another point (and I know this is your post - sorry) I intend to use a rubber cargo mat - can't think of the correct name, from Clark - I nearly broke my arm when I went in to do the underside of the rear window reveal - the hammered metal epoxy is so slick, if I'd taken my shoes off I'd be posting this using my laptop from a bed.
I used it on all the cabin floor/rear seat etc and it is magic.
In the boot, will fit it (non-adhered) and re-fit the boot mat over it.
On the floor of the inside, I fitted two layers of it, with an absorbing material between them (to stop any grit/sand etc filtering through the carpet). It gives a nice "soft" feel to the carpet, just a little.
I don't know if it absorbs any road noise - but the result is probably as good as the deadener I removed used to be.
From what I have seen of your body work, it has been the biggest contrast to from ...... to......... I have seen yet - I am amazed, Dave - tell me, do you work professionally in the field?
If not, then I am even more so.......
You are galloping on the back straight at present - at this rate (four and a bit months) I now think the "creature comforts" vehicle is going to be left at home..........
Keep it coming, Dave - very well done.....
rosco on Sat Jan 26, 2008 7:42 am, edited 4 times in total.
