Dave's Orange Betty EK Sedan
Orange Betty
Post by Orange Betty »
Thanks Blacky, that is certainly a more palatable option. And thanks for the offer Billy.
I'll try to fab something up first just for fun...
Dave
62 EK Sedan in slow progress
Orange Betty
Well it's been awhile - again... But started work on the right rear qtr panel
RR Qtr.JPG (69.97 KiB) Viewed 3421 times
I have the Rare Spares lower patch panel so cut out a section to reveal the inner swiss cheese
RRQTR inner dmg.jpg (57.13 KiB) Viewed 3421 times
Donor section not perfect but salvageable
inner donor patch.jpg (65.62 KiB) Viewed 3421 times
fixed inner.jpg (113 KiB) Viewed 3421 times
Now just trying to get the Rares patch to fit.
But I haven't been idle, I have alot of vintage/retro mountain bikes to look after....
And more car related I finished my first engine build, as practice for Betty's grey motor.
The Junk 186. 3 pistons were completely stuck in their bores and I broke 2 persuading them to come out. No 1 bore is waaaaaaay oversize, out of round and tapered and understandably only has 30 psi dry compression and 50 wet. The rest average 80. But it runs, so I didn't do too badly. The only new bits were bearings, rings, gaskets, fuel pump, spark plugs, leads and bits and bobs. The rest were original to the engine or used parts sourced elsewhere. It was good fun and I enjoy running it and disturbing the neighbours!
Dave
Dave
A green Holden six….. wow!! With cylinder bores like that no wonder you don’t see too many in action 😊
Dave,
I've lost count of the number of 186s I've had to bin because no. 1 cylinder bore wore badly at the front, and then the rings broke.
But I like the engine test setup. The music stand sets it off beautifully.
I can vouch for the green. It's very loud. Imagine a green motor in an orange car. It hurts just thinking about it.
Glad you're back on the rust Dave. There's not much to go now.
Orange Betty
ardiesse wrote: Fri May 26, 2023 5:09 pm Dave,
Hi Rob, why is it that the #1 cylinder wears more than the others?
Dave
Nice work Dave. Love a salvageable donor panel, and I like the green donk.
Dave,
You asked why number 1 wears out faster than the others. There's probably a Ph.D. to be had in this. It's peculiar to red motors. Some half-formed ideas:
The water pump impeller sits hard up against number 1 cylinder. You could imagine a situation where cavitation seriously reduces the heat transfer from the cylinder to the coolant. The top of the cylinder bore dissipates more heat, and the front of number 1 is subject to poor cooling anyway because of cavitation. So it gets hot. And it's the most "uphill" place in the motor, thus the most prone to lubrication failure. So I think it's a bad combination of high heat load, poor cooling and poor lubrication. If the motor was driven hard and not well cared for, all the conditions for rapid bore wear would be met.
And another thing - all the 186s I've binned because number 1 bore was flogged out at the front were 192s. So I think that thin cylinder walls are a contributing factor.
Who on the forum has experience of Valiant motors, or even f... ff... Ff.. ?
Not me. But I can attest to 192s having cooling issues.
The Low Compression (LC) Green motor was the model between the Red and Blue motors. :mrgreen:
Never had an engine wear out like that but I have owned all the others but not Vals.
I can only tell you greys break the snout of the crankshafts in the number 1 bearing cap.
Reds will pull the block apart and crack horizontally to the bores, from memory number 1 was the worst.
When I used to be involved, the HQ boys would bore the 202's out in all cylinders except number 1. This may have been because of Robs info but the smarties did this so when the blocks were inspected by the officials they would measure # 1 only and move on. That was of course eventually found out. A liitle advantage was always required in such a tight ruled class !!!!!
As for frauds, I had a couple of sixes that went for ever and I never pulled them down, one of the 250 ci went between 3 cars before ending up in an XP which my family still owns. Mmmmm might drag that old girl out one day.
Orange Betty
ardiesse wrote: Fri May 26, 2023 8:00 pm Dave,
Ahhh, makes sense now that you say it.
Dave
Orange Betty
Harv wrote: Sat May 27, 2023 7:37 am The Low Compression (LC) Green motor was the model between the Red and Blue motors. :mrgreen:
:lol: :clap:
I miss HQ racing, back when panels and subframes were still in wreckers. Watching that mob throw horribly heavy cars door handle to door handle was very cool.
Harv wrote: Sat May 27, 2023 9:23 pm I miss HQ racing, back when panels and subframes were still in wreckers. Watching that mob throw horribly heavy cars door handle to door handle was very cool.
I remember watching them at Bathurst one year racing 4 wide into the corner - the tyre squeal was deafening ...... most entertaining division out there :thumbsup: :thumbsup:
